I’ve been using it for a couple of years. It is easy to inspect and to clean. I purchased extra o rings, which I replace every couple of oil changes. They can be obtained through McMaster Carr for under .50
Hi Bill. Do you by chance have the MC part number? And, do you (or anyone else) know if the same gasket works for the K&P version?
One thing to note is that oil temp will probably be down. In my case quite a bit, to the extent I may have to put on the oil louvre even for summer. B
Interesting! Any idea by how much and why?
I checked my old engine data and saw no difference in oil temps when running the K&P vs. a disposable Tempest. Obviously others’ mileage may vary!
Same thing here which I was hoping the filter will help with the oil temp. I even added a 1" blast tube and pointed at the oil filter with no noticeable change in the oil temp so I remove the blast tube.I noticed no change in oil temperature either. My engine was well broken in when I switched to the K&P filter.
