Good Morning:
I had difficulty lining up the “loop” at the end of the CT A-740 Black with the hole and the cotter pin. While attempting to open the loop to make it larger, it broke. If I rebend it, it would be behind the hole. The M341M was nearly fully extended when I was assembling everything, but the F-1210 was up against the cushion clamp. The red area shows the location of where the wire broke.
Can the wire be replaced without purchasing the entire CT A-740?
