RudiGreyling
Guys,
I Unpacked my QB and I see the RV10 has double layered and riveted floor all the way through. The interior floor skins are just temporary fitted on the QB with a pop here and there...
On my RV7 Vans recommends you could run the wires in the tunnel both sides to the rear, and one could mount the Bottom Antenna under removable Seat Pans to get access to them.
The riveted double flooring and heat + Rudder cables + Pushrods in the tunnel makes me wonder if I can repeat the same on the RV10.
What are you guys doing here for rear wire runs and bottom antenna?
Thanks in advance,
Rudi
Thanks in advance,
Rudi
