Boost Pump plumbing
Ralph Inkster
Anyone have a boost pump like this & have a picture how the bypass loops are arranged? Looks like the blue pump was used as a replacement for the original.
try this Ralph-----RV7 version, but essentially the same for all version 1 AFP boost pumps.
Tom
I have boost pump that looks exactly like that one.
I got it as a replacement for a high pressure Bosch pump in my Jaguar.
The Bosch is 150$ the blue one was 25$ On ebay. Works
Fine in the Jag. YMMV
Order
Order an Andar pump from Vans,. Easer install. No return lines. Much better system.
Air Flow Performance 2090255 from either AFP or Vans. Easy in and out.
Tom
The replacement pump
Looks like what I got when I ordered the E2315
However it is NOT a drop on replacement
Much bigger and inlet is at center instead of offset like 2315…. Thus messing up all the clearances and arrangements of original
Guessing it would be easier to get the right pump,…
At least that is assumption I am working under
