D-Dubya
I am seeking insights on an issue with my RV-7 that's equipped with a parallel valve IO-360 engine. Specifically, when the engine is hot and at full power during takeoff, there's a sporadic 'pop' or 'miss'. This is perceptible through the rudder pedals and stick and confirmed by ground observers anytime I takeoff when the engine is hot (like during a second takeoff or go-around).
My first hunch was that everything was getting heat soaked after slowing down for landing and it may be experiencing a vapor lock issue. So I tried keeping the power at cruise settings all the way through a descent in smooth air, then applying takeoff power at 1000’ before arriving in the pattern. It’s the same thing; still the pop/miss at WOT & higher RPM.
Key Observations:
- Occurs only under three concurrent conditions: hot engine, full throttle, and full RPM
- Reducing power to 25” MAP or RPM below 2550 eliminates the issue
- Issue persists regardless of mixture settings
- Higher CHTs (usually under 405 degrees F) observed during second takeoff, but cooling quickly upon power reduction
- No issues during first takeoff or at high altitudes
- Fuel flow decreases from 17.5 GPH with a cold engine to 16.7 GPH during second takeoff with a hot engine
- EGTs are similar during first or second takeoff (approx. 1330 degrees F)
- Magneto timing confirmed with both at 23 degrees BTDC
Maintenance Checks:
- Regular borescoping of cylinders shows no concerns
- Performed In-flight LOP Mag Check, Mixture Distribution Test, and Induction Leak Test with no clear issue
- Compression tests show all cylinders in the mid-70's
- Servo levers' range of motion confirmed stop-to-stop
Engine Details:
- ECI Titan IO-360, 185 HP by Barrett Precision Engines
- Experimental version of RSA-5 fuel injection servo
- Cylinders 1-3 have 0.028” fuel injection nozzles, 0.029” for #4
- Bendix magnetos with G3i ignition interface, Champion REM40E spark plugs
- Whirlwind 200RV constant speed prop, forward-facing cold air induction, custom plenum
Although it went undetected during Phase I due to single-takeoff flights, this issue is concerning since I don't know what it is. I am the original builder and seeking suggestions for further diagnostics or experiences with similar issues. More information is available, but I was trying to keep this post somewhat brief.
Key Observations:
Maintenance Checks:
Engine Details:
