a month ago my alternator quit charging. it is a n.d. 40 amp , internal reg. and 40 hrs on it. i took it to a shop and the regulator was replaced. i reinstalled it and it put out 14.1 volts again. before a flight i taxied it a little and after a minute it wasn't putting out anything that would show above 13 volts[ batterie's charge]. i ran it up to 2700 rpm [honda engine, redline 55oo rpm] and it started putting out 14.1 volts again. after it sat at the hangar a bit i ran it up to 3500 rpm and no output.
t.t. on the plane is 40 hrs. in all that time it has never put out anything but 14-14.2 volts. and it has always done this at 1700 rpm.
i have checked everything..field wire, relay function in the ovm circuit,etc. i am convinced this is in the alternator. the alt. has had its model number removed so i don't know what model it is. here's my question........the shop has a good reputation. they didn't spin it but tested all components electrically and said all was good but the reg. was bad. can an alt. be tested without actually spinning it? should i just order another alt.? without a model number it's tough.
