Ed_Wischmeyer
The first automotive alternator (Suzuki) lasted about a thousand hours before it went belly up. It was replaced with a rebuilt one that lasted about 50 hours before it failed in flight. And, of course, when it went to the shop, it worked just fine. Not to worry, I had a spare (new) on hand, just in case.
The new one works, but whereas the previous ones showed 14 volts in flight, this one shows 13.6 - 13.8 volts in flight. (I'm not sure how accurate the voltmeter is on the G3X touch, or if there's an undocumented diode somewhere in this installation, or...)
Is this normal tolerance? Anything to be concerned about, other than charging in flight would be slower than at a higher voltage?
The local shop lost their electrics guy...
Thanks!
Ed
Thanks!
Ed
