MED
The VPX in my RV-14A displayed an alternator fault error just before we landed at BAK on the way home from OSH. The fault cleared on the ground, but recurred after departure. Fortunately, I used the stand-by alternator to make the approach into BAK and for the flight home, so we were not stuck somewhere in Indiana. A forum search suggested the problem could be in the plug - a broken wire or corrosion, since the plug is not potted. I wondered if the problem might be heat related. I inspected the plug and wiring with nothing observed, then flew a test flight and the alternator fault recurred. So, I ordered a replacement Plane Power alternator from ACS (1AMU + $200 core charge) and installed it yesterday. This morning, after rechecking everything, I cowled up and flew. No issues, so the problem appears to have been internal to the alternator. Monday I will return the core for my $200. ~343 hours at time of failure.
