rvanstory
Well, they say 3rd time's a charm!!! For all you "average" builders (like me) that struggled with the trim tab bends, I FINALLY found a solution that worked very well for me. Thought I'd share it in case you are approaching that step in the plans (9-16).
My struggle was with the suggested Van's "wedge". Both times the wedge would slip (bottom 1st try, and top 2nd try) that damaged the skins. In spite of my best efforts with 2-sided tape. The third try NOT using the wedges worked!
Here's the method that worked for me (on 3rd try!!!):
Step 1. Take a flat piece of steel and round the edges (to not crease the bend) and taper one end to fit up into the trailing edge bend.
2YzTatfxfkIO_YtAfmjAM5Sv-2VxiDdUUM3Z40oTD2aLNNGQKq_4_mlFMfpl2SERj1ld1koeFInYm1_Fgvq0QLlqb6hAQnxpAf4u5pELRMBSY0lmA_qi5MlWNJxsaLZXcmFTN6NvjF_cryPtDP2zkWgfY9-rZVuBIJehtEXwoIy7S3rCaDbnjMqWIFT1Dtc2Xoh4vHvGamY3FN2uplUTwC7MCdAEcY6NfHtgEvwZPNLX_255_dxj8zjWcoqycCx7U0KcO2DPX16co0aLiDZ_t2gajAsAL6VnZipgiEtszcbALgJfbzqsPzNtnv73u4jJS8hCzhfaT1Yu1rbbKE-FCerrT9Od16ODS9-LvOvX70XdO6oejCWKqkg6t1ZIcBuDTl_BKSEOSua1kS8T26I33ZSpQ3_Hb2IzXuMjFdUHDHN84a51HySGP8fVlqStZNwMDWQj3Ke3iFGqLtU5SAftXyfI_3Fg9U1rm_63qjyncj1AqFb26PsmIjgb--dUW4jXM_MxspUykknSueyCEwTUzxZ3rZvnvlyaeePZm9ScF1tz_EZZ1g00H4z4C1mgBD5QCXlcyaf_dSQriHAUonsYdohmQ2vZgIZRG4ksNqEwgaeOTC3TohPk8aHPlRrHddRxz_FejZFL5POomDwzZGhR4ne-nH1SY9Pej2xbWQTGWw=w1035-h776-no
n2ilydgfe4udENPl9W6pLiPsAHF3J4YM9g11iD9UvirGEAFPV_ZtwkqV1QZLZCp5MBiL-66_TAWvcTM56iVaLzcgad3SNA4itm0OMtPqKJ4SzktiQIUZ__9kkNMTcQD-5vO6pxHAVlE1mEuhiadklunz9FZGPXI1G4vvPj1zbLdkXi0qW91CGrrzxVPP2djkrh4acaK3W0iVa5n5Xd8U4wrX6bpVVgoXR3DcpFrUzh84lhwHdLi4aTfdPYJnVq1Z-xN3d99TJyv78RKmvgAQYfeAWUB8jJKQS7jpHrES7uWrfV3cYauv5q5IvkK-94AMKUYb2lUnTlLKoDhrNTb1ZiyicJHFXSGouR1xKvTz3of6ht9ZNUZmRAe1PesBn5PU4MekUO44QGr375bxskXp5_HTF1iXx-QwsagsiB4IcJS81Iy79OS7VuqSK8gq3uMRW2Ik2SKZlXu-n60pifAe3yO6TqXvFdgwEFHCsL52L1hSBYt9_I8qeR-QBeD4U3_hUXAO7abOSIrf7LBcm0qNPTuq7dAuIBUg7V6xMHvNffga8jWht8d5Na92jUi4urM612CndWyg9xAt8nwSm_3DTlrDjFOOtqgvOsC0xAs1LLgyeUwftKgVPYUX7mPdLWz0Y2OmN_cCG9mm8086ftAifIEequjc4G90vY18IBOUSA=w1035-h776-no
Step 2. Clamp the skin between the steel bar and edge of work bench. Let the edge of skin and bar overhang the edge of workbench slightly. It helps when tapping the bend with a rubber headed hammer. Once clamped, tap (slowly) the edge over with a rubber headed mallet. For the small tapered end, finish it's bend by slowly tapping with a upholstery nail hammer. Using the steel bar instead of the wedge allows you to slightly "over bend" the tab to allow for the spring-back effect.
c8h6hEQn2qC9ys1kYdCDZnOlp__4gs98iCvoIHtk6YyTHin2RCezSuM_Vc79X9yFHeFXfctMQCUGz_-lcP678X8rhQgjh29gHMYXG0tYj0zAcxvt1m3Q1PNnYFi1NBfiSQelHLDbXfrtBvJKvD-El95vxnl5HkPaHINuYStxi-81V_sd4iBNmbfLnMAIztOrqIDORoMuK9V9Mklfm2NPeE050ObFbXF0FMN6TJmAPVXrJyG2evVIamTkT8Bxqe22vKEO4SoVw6Slk5PFtjt-amwe-aDXHqApgWbdUe-MwGzrib1Gshg5jaOrMnxOj207SaXur2p990YLaU-rygeT1hL7GULu5FaEh7EmNAVMuQURt1TmPGlPYuNdONHobDOnRYkhAoBvHASOdDW-7gT8T2scLwx44LQ-aJIWyawLr1Zuy-GDWo4fuY-IlZAAwC27egNZxyaovB1q9nsMvmQO147uZ5TLh3brx1OVhC_pyMRSh-1tBSr13GJpHu6lqJ4j7A_vrKLvMq4vt6hX-7A92sS4WhiGCHilqxUsQaTT2S0eJIJiO8kZgGQ8RXdpsZqTekYbuEqpCxifFU9rB74NkmVuq-8Mp3lq1JOjtghylkkBfEL4JOfVmVY0QvdOeWuxEuUF0MMn6eYyWvKzqHtXKhYaSTfS8cy-qMMndle7OQ=w1035-h776-no
kJ3j2FvSGRvBuDFNV1uLmbMXiJHn9u71mqAPpEj1vQqEr9j_-E6wk4nD__H8sbYM1D2Yh8CZYLuPy9GydtnZSutGmP18V3VbsCyVJk1QfHzQOofbisd6hFTS_oGdN7rsssFV3wu0MmLF9stEnFOTPl2-kX4ukDrVsoRBdFoLD0uai0AdpeyddIQyIUjH_iI1V7MVEuttcIjVCAVXMFYS5K_pZ1r1eL_WcA2KBVd4uQSZSdqq7xrTZt2pJxqHmtdB8oThW9h36BJHmoU9rinimaLvwas_IWmXTTPlYWDSMrtn2rHplPQrofZtYzggIGdQfeGPHIpEETv7Wo9NehEd4K4nbEqjO3mLd_emkI1upg_yjAa6er-JgGM_juegSRLoF8roCASIioX-cwjNq_ZISJ26DBGBbrkNVQVceH8Mojrlw-cn1D39RXyfDlHu1erpkAgnPbErL7AKeCB01A2C-QNBxIg89-bMsCG17gMCenut78kMJfd-XBLXaGv0Aq9i9sScNOdRo2lYZJBDqic0jc1SL-Q7DkkGcQqkAKgDUDEpDfB4-KDm7dEBhIkZIyYTacgj3bGPV77lE2ZrMjeGyAUyKuQuO2P94O0XeRtqlA9lYfoUYdHVbAkIL8fIHh63qjl5lJGLejsk2Ak1b2IEUqHIqVw5pkqFaQC4KaNSnA=w1035-h776-no
I also found bending the OUTER tab first worked best. By bending the outer tab first, the two skins came together nice and flush against each other. Hope this helps someone else avoid the frustrations I've had with this simple little part of the build!!
yx1bBZJOYEG28qKIHO_vA8y2F8pzukFQsZShZjBFIRxrQFRIAxanZkw2bOJzdv9av0uBvGFXXqs99Pmfiil2sdSR2uIaPJlTrgiWOLlBnzBq0NnUZ9Z2kmgapBeK8W3Ea_QMvqfaoLgoYWsxGeAoZgUjcacvKtgz0abCpTEDmipFMTngZqmI41JiVL0-oeNazck6YzjcpREw5jgxMu0xeoGYo1i0UdNu1KAGwqmKs7Mar1CMuJCM_EU6ND87-tE5Y8t0WDrDKBVDgrOrKpuE6ihLK06Ub-iUl6yu7ImBV0XyzlnxsF5be_IXY7AaRfa7K7BiK7xvI3YSb-mgRStk0_bbV_DOs5o1LHQCFZKJrSdeGekr09XjH6sA_tzuyosTF3P7FEt19hYNlozfTTavxxDmbRw_43WxWuU0AMMqKhNgLrapaSk6QMA633Ywo26eDHsA9RRiK61aYn2kZ9jPJJ6czBegYBupt_eb7C5XDiKzgI3iZVYgS5Uxq7e-Vp_Cha07NisQIsHrgdfr20ikgqCBLJvpdXCmmtGZo5swr3FaTGn48pBGMHRU-XkONqG_eg33q6qh0FZ_YALl3vqWCjIu-tWgnDLPuoXspcYGt2N8b--qjFS0k0w77WvSyqSrplkn1zef-vVfaCwrO7Swme-tAuVGhgqJZu24U354xw=w582-h776-no
Thanks for this idea. I'm very close to this point in the build and will probably use this method.
Having bent the elevator tabs, I'm really wondering what the big deal is about this. They are both 16 thousandths thick. Bending the elevator was easily done with a piece of softwood to start and then finished with a hand seamer. They turned out perfectly.
I hear you! I thought the same thing. The difference in these and the elevator tabs is that these skins are one (not separate top and bottom). With the elevators you were able to use a "flat block" clamped down to hold the tabs while bending.
In my opinion, it's the Van's method they describe in the instructions (using two wedges) that makes it more difficult. At least that's what created my issues. It was the slope of the wedges that kept the clamp from holding as well and they slipped on me. Each time damaging my skin.
The method I described in my post does away with the sloped wedge and allows a more solid clamp that won't slip, just like the elevator skins.
Hopefully you can become a member of the ONE TAB CLUB by making it easier on yourself the 1st time. :)
I just did this step a couple days ago. Lol.....confession time. I almost made a big boo boo. I clamped the skin to the edge of the table and bent it before realizing that I had both the top and bottom skins perfectly together and that I did both skins at the same time!! :eek: They both were perfect! Luckily it was the first skin(s) that I did so all I had to do was swap the bottom skins. What was originally supposed to be the bottom R became the bottom L. :rolleyes:
Needless to say, it was a little less stiff rolling the other two skins one at a time.
Hey Randy.
I used your method today to finish up the L trim tab which I pressed last night. It turned out perfectly. After clamping I used a small block to gently hammer them into place. It really was a total non-event. Thanks for posting this! :)
Now I on to the R trim tab.
All the best!
Took me 4 tries. I had set the trim tab aside and moved on to other stuff because I was so frustrated with it. Well, today I went tried this technique. And, It worked great! Thanks!
I used a heavy steel back-riveting plate on top before finishing the trailing edge bend. I also attached an aluminum straight edge on the face/edge of the table top. Nice tight neat bends. Very easy to do!
I was only able to get the vans method to work by adding double-sided tape to each block before making my bends. Any way other than this and they slipped like mad and ruined my bend. Glad you found a better way!
Agreed... the method described in the plans will only work if you run double-sided tape along the entire length, on all contact sides of each block before making the bends. On my second attempt (must be an RV rite of passage :D) I personally used 3/4" Intertape 591, (https://www.amazon.com/gp/product/B0178G341A) and had zero problems doing it the plans way with this tape; it sticks like crazy (but is reasonably easy to remove) and is the exact width of the blocks.
I'm about to try out this method, however I'm going to note that I tried using my back-riveting plate like this for bending my elevator close-out tabs and I ruined a skin by using my rivet gun against the side of the metal plate. I think metal on metal on metal is a big no-no. So I assume here you are using a non-metal hammer and/or have a wooden block between the metal and the hammer?
I wasn't happy with mine, and ordered replacement parts quite some time ago. Some of the parts are LCPs, so I'll reorder them one more time and make use of this method. Thanks!
I appreciate the description of the replacement skin on Van's store:
"So, your #*!@ tab didn't quite come out the way you wanted it? Just use our handy trim tab skin and get the thing right next time."
Agree, with all the sticky tape this works. Just completed my #2 set. Results are acceptable, but above method looks even more improved.
For my third and fourth trim tabs, I used (more or less) the method in the original post here. But I just used my back-rivet plate instead of acquiring an extra piece of steel. I rounded off one corner and the associated edges with my grinder to make sure it didn't damage the trim tabs.
