Kay F …8A acro bad@ss at 84 yrs young
Wobble test / DIY Fixtures
I know this has been discussed before but there are a few items that I discovered on my journey to do mine.
First: this is a Lycoming Mandatory Service Bulletin. Is that actually something that HAS to be done? Or is it just prudent? I think it is most important with a certain group of engines that came from the factory with less than good valve guides but apparently is recommended for all..... Several mechanics I have talked to have said No and one or two asked What's a wobble test?
14-07 Step 5 question …14
My question: When do the AFT MOST holes get riveted?
Spring extension
How do I get that rod end bolt onto the prop governor actuator? …7
Are people using a castellated nut and cotter pin here? Not a bad idea and certainly nothing wrong with doing so, but my plans show a MS21042 locknut there:
Admittedly, the plans are inconsistent about the use of castellated nuts versus locknuts on rod end bearings in the FWF area... drawing OP-22 shows castellated nuts for throttle and mixture, but OP-26 shows locknuts for the same controls.
West Coast Formation Clinic 2024 - Madera, CA …Cougar
This year’s West Coast Formation Clinic 2023 will be on April 25-28, 2024 in Madera, CA KMAE. Applications will be closed by the end of the day on 19 March 2024. To apply and/or for additional details, visit the WCFC 2024 website link below. Open the page and clink on Application tab and submit your info.
OFF TOPIC:
PS: Older issues of the ‘VAF News’ can be found at:
