Hope you had a nice weekend and got to spend some time with your RV plane or project. v/r,dr
VAF POSTS & RV NEWS THAT CAUGHT MY EYE.....dr:
What did you do with your RV this weekend? (March 16 - 17'ish)
Update: RV-4 #4175 Fastback Conversion
Small progress today. Made a work platform and riveted some angle supports for it. might need to make another, but I'll deal with that a bit later if I need it. Did some more cutting and have a plan for the flanges on the bulkheads to take up the extra space from the bulkheads since the RV-4 is wider than the HRII. Still trying to sort out exactly how I want to handle bulkhead F407. The longeron slots that come standard from Harmon have the bulkhead sitting much too low for the seat back without cutting at least an inch off the seat. I need to move the bulkhead up a bit anyway to get the canopy transition line I want so I have a few ideas for that. I'm also planning to attach F407 at a slight angle to avoid some binding and chafing with the canopy after discussion with HFS. Canopy is also on order finally so should have that in a couple weeks hopefully.
21is/U Page 8 …12
Stuck Canopy …bruceh mod
I added a spring to the handle shaft and positioned the block so it won't turn accidentally. You have to pull down to rotate the handle to the locked position.
Post in thread 'STUPID mistake: closed canopy with no one inside'
Official construction is beginning, but an issue right out of the gate?
First Carrier Trap
https://vansairforce.net/threads/first-carrier-trap.225356/
Riveting VS root rib rib, nose rib, and forward spar
It’s DanH’s Fault …Webb
Daily RV Pic
OFF TOPIC:
PS: Older issues of the ‘VAF News’ can be found at:
