The part is different
Call Jimmy - He makes the stuff now, so he MIGHT tell you the right P/N.
512-429-0230
K&N Filter
Im looking for the filter that Rod used for a forward facing induction io-360, not having any luck finding a part number. The rocket pn is not the right size for mine. My filter is 6 1/2 tall, 4 1/2 forward opening, 5 3/8 opening at the throttle body.
If u don’t get the p/n here I’ll advise tomorrow after I go to the hangar - I have the same setup as you.
A Little Clarification
These are K&N's dimensional descriptions:
Mounting Flange Inside Diameter:
Filter Base Diameter:
Filter Top Diameter:
Note here - The filter comes with a closed in top, Rod cuts out the center, inside the pleats to provide a mounting "ring" for his Ram Air Valve.
Filter Length: (does not include mounting flange length)
Flange Length:
With these measurements, and the K&N catalog, you should be able to pick out a replacement.
HFS
As promised - it’s K&N RU2520 😉
Specs for RU 2520
Not sure if these meet the dimensions from the op's original post -
Mounting Flange Inside Diameter: 4"
Filter Base Diameter: 5 3/8"
Filter Top Diameter: 4 3/8"
Filter Length: 5"
Flange Length: 5/8"
HFS
Option to K&N
I've become less enamored with K&N over the years. Has anyone replaced the K&N filter in their Rod Bower filter system with a traditional filter?
