BH1166
I’m looking to replace mine, 32 years in use, have something going on up there, a simple “rule out” item to change. Blank finding it in the Vans Store. Would rather not, but could remove, measure and find vendor, order.
disc spring washer source
And if you search on the "Cross Reference Part Numbers: AI-251280" listed on the store link in Paul's post, you end up with this web page:
https://www.mwcomponents.com/shop/ai-251280
Since disc spring washers come in standard sizes, I'm betting you can find an equivalent part (size, and material spec) from lots of places.
As an aside, before opting for new parts, check the breakout force on the nose wheel to make sure it is at or near spec. Strange things can happen it is too high or too low.
If you opt for replacement, check the breakout force now, and in 25 hours. These things seem to "wear in" a bit.
