grayforge
Arrgghhh... Test fit my W-716 stick to aileron bellcrank pushrods today and found them too short. :-( Ailerons in trail and bellcrank jig in-place. I did a test: turned the jam nuts all the way loose, then spun the pushrod in one direction to see if it would stop before... plop... the rod end fell out.
I found a number of folks with this issue on VAF. A common solution is to use rod end bearings with longer threads (MD3616M), but these look to have a thicker ball requiring adjustments to washers at the stick and spacers at the bellcrank. Has anyone found a rod end bearing that's identical except for the length of the threaded shaft?
I could also build another set of pushrods :-( or add an extra jam nut to each rod end bearing to use up available thread space for the pushrod to twist off.
Thanks!
Russ
Thanks!
Russ
