Old 05-04-2013, 01:35 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Lycoming vs. ECI vs. Superior?
I am shopping for a 6A/7A with an I/O360 and note that engine choices among the flying aircraft are Lycoming, ECI, or Superior. If I have an ECI or Superior engine, in the event of needing parts (repair, overhaul, etc.?), will Lycoming parts be interchangeable with the ECI/Superior?
Old 05-04-2013, 02:14 PM
N941WR's Avatar
N941WR N941WR is offline
The ECi and Superior engines are made from PMA'ed parts. Meaning they are essentially Lycoming clones but without the data plate.
In fact, my ECi engine is assembled using the Lycoming overhaul manual.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-04-2013, 02:39 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Just be aware of any AD's and SB's that apply to the potential purchase and see if any you are looking at buying are affected.
______________________________
David Brown
The two best investments you can make, by any financial test, an EMS and APS!
Old 05-04-2013, 03:03 PM
Jeff A's Avatar
Jeff A Jeff A is offline
In every single case....no. In most cases....yes.
If you buy a Superior engine (or ECI, or Lycoming) why not just pick up the phone and call the respective manufacturer for any needed replacement parts? You can purchase piece parts from any of them.
If you're "in the field" needing emergency replacement parts, and the local shop only has genuine Lycoming parts, refer the first line.
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 05-04-2013, 03:15 PM
Kahuna's Avatar
Kahuna Kahuna is offline
Whelen LED Light Man
ECI is now delivering assembled engines. I had the opportunity to first flight a 370 stroker (205hp) in a 1124lb RV-6 yesterday. Its quite an engine. Smooth, powerful. The best power to weight in this cost class as far as I can tell.
Old 05-28-2013, 01:58 AM
grayforge's Avatar
grayforge grayforge is offline
The ECI option looks interesting. Would love to check out the 370: 205hp.
I tried sending them an email, requesting a quote. Still no response after over 2 weeks. :-(
Speed Is Life
VAF Donation made: 3/31/2017, My RV-7A Build Log
Old 05-28-2013, 11:17 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Pick up the phone and call them. I used to talk with Bobby Looper, one of their testers, quite regularly when I was building. Cannot reach him directly now but they will gladly direct you to the sales reps and you can talk with them on the phone about your needs. There number is 800 324-2359.
By the way, I am not affiliated with ECi in any way other than a satisfied customer.
P.S. If you need an engine shop to build your ECi engine you should consider these guys, America's Aircraft Engines. They are a great shop to work with.
RVBYSDI
Steve
RV9A
Live Long And Prosper! 🖖🏻
Old 05-28-2013, 03:33 PM
KRviator's Avatar
KRviator KRviator is offline
Strange that you haven't got a reply back... I got one within hours when I first enquired about a new O-320. I was referred to one of their sales reps, JB, who has proven more than helpful answering my queries and sorting out the logistics of customising my engine then getting it shipped to me in Australia - where it is currently clearing Customs and should be ready for pickup this afternoon! You can you can try emailing him direct here. Due to the time difference, there were a couple of occasions where I'd get a reply literally within minutes to questions I'd raise.
FWIW, I ended up getting an assembled & test-run low-compression OX-340S, with dual P-Mags and automotive plugs all round for $25,600. This doesn't include a carb though, I'm going to use a Rotec TBI instead.
From another post I wrote on the subject:
Originally Posted by ME!
Figured I might as well add this in here as a datapoint for those interested, having just ordered a new donk from ECI.
An OX-340S with:
  • 7.2:1 Pistons
  • Dynafocal 1 mount
  • 14mm plug bosses & automotive plugs all round
  • Dual P-Mags
  • Low-pressure, engine-driven fuel pump
  • 2 hours break-in on their test cell
  • But without a carb
is going to cost me $25,604, including crating but excluding shipping - which given I live in Australia is likely to cost more than the engine anyway. A new carb would add ~$1,500 to the price, but I'm going to install the locally-made Rotec TBI in its place.
The -340S with the low compression pistons will allow regular running of Mogas with an increased detonation margin while still delivering ~160HP, and also fitting in the footprint of an O-320. Cheaper flying is always a good thing.
Turns out shipping cost $1,250USD via DB Schenker, for an approximately 7-day door-to-door service. Of which half is waiting for Customs clearance...WOW!
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A 19-8519 - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Phase I done. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
