Finished wiring my stick and wondering the best way to have the movement needed and not so much loose wire to cause a problem??? I'm sure this has been discussed somewhere but can't find the right words to search!
I drilled a hole in the side of the stick at the articulation, it's the single point with the least movement. Used one of the small plastic bushings in the hole.
