So I just fit the tank to the main spar for the first time, and everything lines up perfectly, except for at the very tip of the leading edge, the radius of the tank vs the outboard LE don't quite match, as pictured. The rest of the joint at the splice strip is perfect, only the very tip is disjointed by about a skin's width.
I am thinking this will tighten up once all is riveted, or worst case scenario the joint could be smoothed with filler before paint, but did anybody else have the same experience?
Thanks in advance as always
Chris
Chris
