BillL
I am sitting on a decision for exhaust system. I have searched here for hours and can not get clear data to move me forward. The considerations are as follows:
Fit: Pipe routing, possible interference with standard components, cable routings etc.
Heating: Only single muff is available, but there are pin-fins on the exhaust pipe to help in heat transfer
Exit: Is the angle and geometery of the exit compatible with cooling area changes like DanH has been doing on his -8? I will do flyoff with standard SJ cowl, and modify later after all else is sorted.
Performance: Mr Vetterman has some good information comparing his units showing basic cruise equality with his best picks for the 4 into 1 pipe with the 2.5/3" dia. I am more weighted to cruise performance (thus efficiency) than low down absolute speed.
Durability: The AWI has seen some fractures (2-400 hr range) and i wonder if these have been resolved by welding processes, design, and/or mounting system.
Anything missed here from your experience(s)?
Thanks in advance for sharing your experience.
