Kahuna
Moderatoring
So about a month ago I had a failure of my 430 where I could not transmitt. Receive ok, but on transmitt, the tx light would come on but no one could hear me.
I tried everything (well obviously not). I stuck the 430 in a Bonanza and it worked. I ran new coax, new connectors, new thru tray bnc's, sent in audio panel for repair, rewired audio panel to comm. I spent a rediculas amount of time trying to find the problem.
It was with great dissappointment that I had to take a day out of work and fly the plane to Stark Avionics. I bought 2 planes worth of Avionics from them. I wired both myself and as a homebuilder, this was my last recourse and I absolutely HATE taking my plane to someone to work on.
I spent 5 hours there with 3 technitions. They hooked up every gismo they had. But in the end, they sent me home with no solution and a now broken 430. They inadvertentantly left a test pin in the tray and jammed up the pins when reinserting the unit.
A day later the chief technition called me and said. " Hey do you have a fuse on the comm circuit?"
"Ahh, yeah"
"Check it"
"Ahhh.. OK"
And low and behold, there is my 5 amp fuse blown. He said replace it with a 10 and I did and it now works.
So how much does it cost to replace a fuse?
1 RMA unit
$140 worth of "Troubleshooting time" for Stark
$.37 for the fuse
ARGH!!!!
"Ahh, yeah"
"Check it"
"Ahhh.. OK"
1 RMA unit
$.37 for the fuse
ARGH!!!!
