Old 09-23-2012, 11:31 PM
ajay ajay is offline
Default new engine worth taking a look-see
katech v4.
160hp. 140 lbs.
draws on the LS series v8 design.
very compact architecture, 4 cylinder, aluminum block, heads, and pistons, pushrod, liquid cooled
Old 09-24-2012, 10:26 AM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
http://www.katechengines.com/engineering/katech-v4/
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 10-13-2012, 04:10 PM
KRviator's Avatar
KRviator KRviator is offline
160HP @ 6,600 RPM though, so some of those weight savings will be taken up with a reduction drive.
At a guess, that 140lb, though listed as dry weight, wouldn't include the oil cooler or radiator either. It looks to be just the bare engine.
Still, that looks to be worth keeping an eye on depending where they set the initial price.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A 19-8519 - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Phase I done. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 10-13-2012, 04:45 PM
They don't have the slightest hint of aerospace applications. This engine would be an automotive adaptation by you, rather than an installation of an engine intended for aircraft.
Old 10-13-2012, 05:49 PM
mannanj's Avatar
mannanj mannanj is offline
Just design a prop that is efficient at 6,600rpm!
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 10-13-2012, 10:22 PM
Captain Avgas Captain Avgas is offline
Any savings on an engine will be lost 5 times over when the installer of any auto-conversion comes around to selling his RV.
Most RV buyers wont entertain the thought of an auto-conversion engine (they have a terrible reputation...and for very good reasons) so that really depresses resale values.
Honestly, every flying RV builder I've ever met with an auto-conversion tells me the same story....they wouldn't do it again.
Regards
Bob Barrow
RV7A
Old 10-14-2012, 06:06 AM
pierre smith's Avatar
Yep...so true.
Just yesterday, my buddy said that the Subie take-out sitting on his hangar floor has to go..around $1,500 for a 4 cyl. Egg engine out of my friends -7, with only 200 hours on it!
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor AT 502B PT 6-15
Air Tractor 402 PT-6-20
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-21-2012, 09:04 PM
simpkinsona simpkinsona is offline
Originally Posted by pierre smith View Post
Yep...so true.
Best,
That's the best part of having a Subie, I can replace it for 1500 dollars. Mine has 515 hours and has been very satisfactory. Looking forward to another 1000 hours or so and then a 1500 dollar rebuild.
-Andy
Old 05-07-2013, 02:48 AM
Default the 4 cylinder LS1
http://www.youtube.com/watch?v=2kooY...layer_embedded
Old 05-07-2013, 10:35 AM
Default 367 mph "motorcycle"
Here is another high reving high HP V4 motorcycle engine for you gearheads to drool over.
http://seven-streamliner.com/engine/index.html
And probably even less suited for aircraft conversion than the one above-----but hey, this is what Experimental Aviation is all about aint it?
