Go Back   VAF Forums > Model Specific > RV-3
Old 09-18-2012, 02:11 PM
Jumbo's Avatar
Jumbo Jumbo is offline
Default RV-3 vs. Harmon Rocket I
Hi,
I am trying to find out what the differences are - both structural and aerodynamic - between the RV-3 and the Harmon Rocket I. I am aware of the turtle deck and more HP however I don't have any knowledge really re the wings in detail and re any resulting change in flying behavior.
If you guys, more knowledgeable than me, would provide some insight I'd be glad.
Thanks, Heinz
Homebased Muenster-Telgte, Germany, Europe
a.) Eggenfellner H-6 powered 4-seat Robin, PH-ERD 325+hrs since SEP 2008 .... counting
b.) bought flying & sold: Vans RV-4 with O-320, PH-EIL .... very sad ending - lost a friend
c.) bought flying at 51 TT: Vans RV-3A, PH-URZ .... now at 150 hrs (and having fun )
Old 09-18-2012, 03:30 PM
pierre smith's Avatar
Heinz, the Harmon Rocket is based on an RV-4, who's wings are a lot bigger in both chord and span. The fuselage is also a lot longer on a -4.
The Harmon's wings are shortened by one bay but uses all the ribs, just spaced closer together. The tailfeathers are also -4, bigger than the -3 and the guys usually use thicker skins back there.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor AT 502B PT 6-15
Air Tractor 402 PT-6-20
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 09-18-2012, 03:46 PM
Sid Lambert Sid Lambert is offline
Scratch what Pierre said. He wasn't paying attention.
The Harmon Rocket 1 was based on the RV-3. Like you I do not know other than the turtle deck and an angle value IO-360 engine what the difference is.
The HRII had lots of changes but again, no so sure about the HRI.
John Harmon is still around and may answer your questions.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 09-18-2012, 03:52 PM
Oops.
You guys see what happens when you're 67?
I forgot about the Harmon I,
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 09-19-2012, 03:24 AM
Jumbo's Avatar
Default yes, HR I (only 4 built) - not HR II
Thanks gents,
As far as I understand the HR I is essentially a standard -3 with a "pumped up" motor and a raised turtleback. I am not aware of any change of seating location for CG reasons as all the parts and pieces were installed in the original locations.
So with the angle valve AEIO 360 I think the CG at Empty Weight (I know the MTV-12 helps over a i.e. a Hartzell) is important. Too, I don´t know about potential flutter of RV-3 control surfaces at say 190kts+ IAS.
Someone out there able to advise?
Heinz
Old 09-19-2012, 05:50 AM
Have you tried to contact John Harmon?
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 09-19-2012, 10:20 AM
smokyray's Avatar
smokyray smokyray is offline
Default Birds of a feather...
Originally Posted by Jumbo View Post
Hi,
Thanks, Heinz
Wie Geht's Heinz!
As you know the HR-1 was a modification of the RV-3 kit of which John Harmon is very familiar. He was one of the original RV-3 builders and went on to assist or build seven more. The HR-1 was basically a beefed up RV-3 with an IO-360 A1B6 up front, .040 forward fuselage skin, single .032 top wing skin, RV4 empennage, longer landing gear, fastback.
From talking to the owner of the one currently in Barnstormers, there were only five ever built. He flies it regularly and touted excellent performance and speeds comparable or exceeding the HR2 he flies alongside regularly. He has flown the F-1 Rocket and says the HR-1 is much lighter in pitch and slightly less in roll, almost Pitts behavior. Most Rockets are nose-heavy but apparently the HR-1 is better balanced. Climb apparently is spectacular, surpassing even the F-1. Having owned a 300HP HR2, that's impressive. (not quite the F16, but what is)
John Harmon doesn't use this site but does monitor the Matronics Rocket list regularly. Most of the Rocket guys are there as well. www.matronics.com
Good Luck!
V/R
Smokey
PS:You can also call him, I have his cell# if you want to email me offline.
The few, the proud...
Old 09-20-2012, 09:47 AM
Jumbo's Avatar
Default Rocket Mailing List
Smokey, Tom,
thanks for that - as per Smokeys advise I have put a post on the Rocket Mailing list (which John Harmon seems to visit normally) with my questions however still all input is welcome.
Best, Heinz
Old 09-21-2012, 05:33 AM
Michael White's Avatar
Michael White Michael White is offline
Heinz,
Let us know what you find out. It'd be nice to know what the non-visible differences are.
Best,
Moose
VAF #136
N424LZ Reserved
Old 09-21-2012, 06:20 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Why the RV-4 Empennage ?
Smokey, do you know the reason for the larger empennage ??
Larry DeCamp
RV-3B flying
RV-4 fastback project in the shop
Clinton, IN
