Any comment re this?
This comment came from a Rotax Repair Center.
Also wrap the muffler?
http://www.matronics.com/archive/archive-get.cgi?RotaxEngines-Archive.digest.vol-ar
Thermo-Tech is very common. You can pick header wrap up at places like Checker
auto, Auto Zone or Pep Boys. You need to get the 2" wide wrap and it is sold in
a 50' length. For the standard Rotax exhaust tube that is about 15" long you
need to cut a 68" piece. Dampen it. Don't soak it. It takes very little water
to moisten this stuff. You will need a hose clamp at the top and one for the
bottom. Start at the top or exhaust port and wrap 2 spiral turns then put the
first clamp on. Then spiral wrap all the way down. Only over wrap each edge by
about 3/8"- 1/2" and no more. If you over wrap too much it hold in too much
heat. When you get to the springs just go under them and wrap around the exhaust
knuckle. This will help with any exhaust blow-by. Do not over wrap the springs.
The springs need the cooler air. Once this is done apply the other clamp.
That's it, just do the other three like that.
If you have an EGT probe, do not wrap around this. The material in the cloth warp
interferes with the readings. It will make your EGT's swing 100F. Wrap up to
about 1/4" before the probe and add a clamp then start 1/4" past the EGT probe,
add a clamp and then on down. When your done let the engine run for 10 minutes
or so.
p.s.
When you start the engine for the first time it will smoke a little and smell like
it's burning. That will go away after about 10 minutes and the wrap will burn
and seat in place. It might give a faint burnt smell the first time out after
you shut the engine down. That's normal and don't worry. Once this has been
run a few times the wrap will be fragile so don't try and take it off and think
you can reuse it. If you scrape it hard with a tool it could abrade.
Submitted by:-----
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
