Old 06-15-2012, 04:18 PM
Don Jones's Avatar
Don Jones Don Jones is offline
Default Home made glide slope antenna
Has anyone tried the stripped coax glideslope antenna in a gear leg fairing?
I have been considering where to put one. Thinking either the cowl or gearleg fairing. I don't want to use a diplexer to split my vor antenna to feed the glideslope to my 430. I suspect it might cause the signal to be directional, just thought someone here might have tried it. Paul??
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 06-15-2012, 09:01 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I seriously doubt it would work at all in the gear leg fairing. It would be way to close to the gear leg. The engine cowl may work, but it would need to be kept away from metal as much as possible. Neither place is really ideal. It may be worth a try, but a splitter is a lot easier. A splitter will not add directivity to an antenna. What are you doing for the nav antenna?
Bill Peyton
RV-10 - 700 Hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 06-15-2012, 09:28 PM
As Bill said, you want to keep it away from metal. Also as horizontal as possible. That makes the gear leg a poor choice.
I use an Archer antenna in the wingtip for localizer, VOR, and GS with an SL30 which has an internal spliter. Works fine.
Old 06-15-2012, 09:36 PM
Radomir's Avatar
Radomir Radomir is offline
Why not use a splitter.. they work just fine..
Radomir
RV-7A sold
Old 06-16-2012, 12:26 AM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Along roll bar
I am not flying yet but plan to do like Paul Dye and run the stripped coax along the forward side of the windscreen, just in front of the roll bar. This has worked well for him so I will give it a try.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
Olympia, WA
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2017
Old 06-16-2012, 01:01 AM
Flying Scotsman Flying Scotsman is offline
Do you mean marker beacon, or glideslope?
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 06-16-2012, 07:47 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Mine has worked just great tucked along the roll-bar on the -8, and on the -3, we id exactly what you are suggesting (running it down the gear leg) and it has done just fine as well.
For those wondering why the spliter....the wingtip Nav antenna is extremely finicky in real-world installations, and the signal strength it delivers can end up marginal. Split it, and oftentimes, you don't' have enough left to drive the receivers. I started that way on the -8, and finally gave up - the simple home-made GS antenna fixed gave me better GS, and also better VOR range.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-16-2012, 07:52 AM
Don Jones's Avatar
Several people have had lousy glide slope reception with the Archer antenna in the wing tip like I have when using a splitter on the Garmin 430. Paul Dye went throuth it as well as Scott Card. Paul ran one up his roll bar and it made a huge difference.
Here is the thread http://www.vansairforce.com/communit...ad.php?t=40633
I don't have a roll bar, so I wondered if anyone had tried the gear leg fairing idea.
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 06-16-2012, 06:00 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
I used a variation of the stripped coax GS antenna in the RV-8... made a 16" long strip of aluminum, about 3/8" wide and fiberglassed it to the floor of the right wingtip, sitcking as much straight outward as it could get, polarized horizontally. Attached the coax center conductor to the inboad end of the strip and grounded the coax to the outer wing rib. It seems to work just fine with the Garmin 430, cost was virtually noting. The coax was the only cost item.
Neal Howard
Airplaneless once again...
Old 06-16-2012, 06:46 PM
Neal's example shows how sensitive modern receivers are; almost anything will work, if it can see the transmitter without looking thru a lot of metal. 16" is "the wrong" length.
For an ideal antenna (that is, an infinite ground plane instead of the finite wing rib for a ground) the length of the antenna element should be about 9". (Remember the "bow tie" GS antennas, high up on the windscreen of 1970-era Cessnas?). 27" also works, and is what you want for the VOR frequencies.
