Paris12Man
Hello,
I have the following issue with my radio/intercom system and I was hoping to get some suggestions here on how to trouble-shoot. I hope I can describe the issues clearly enough for you to help. If you need more info....let me know.
1.....With the engine OFF, everything works fine! The radio is crisp and clear and the intercom can be adjusted to perform as it is suppose to. I've transmitted to other aircraft flying overhead and they respond that my transmissions are very good and no static.
2.....With the engine RUNNING, the intercom cannot be adjusted to work properly. Either you hear a lot of noise and be able to talk, or don't hear anything and can't communicate over the intercom. Using the radio brings the following....when you use the PTT button, you hear a lot of noise. I'm able to transmit and receive ok and everyone says the radio sounds fine.
My opinion is that I have a lose connection someplace in the wiring. Does anyone have any suggestions on how to trouble-shoot this???
Steve
Steve
