aturner
Well, I was primed today to mount the engine, but ran into a snag. I knew I had to change out my large-hole engine mounting ears for small hole ears, but I had purchased those some time ago and had them in storage. Problem is, my small hole mounts have short guide pins on the bottom, but my engine case is not machined to accept them:
old mount on left, new on right. So, what happened here? The new, small hole mounts have the part number 70456 cast onto them, and then have 71047 stamped on the other side. Should I just spring for the new AERO mounts, or do those have studs too? I guess I don't know for sure if it is my ears that are weird, or my engine case. ???? Should I just yank those little buggers out?
