Old 06-16-2006, 06:56 PM
mhflyit mhflyit is offline
Default Canopy hole enlarging
Vans calls out a #27 drill size to enlarge the canopy holes after they have been initially drilled along with the frame to a size 40. My problem is that I can't find anywhere online that sells a #27 plexiglass drill bit, the smallest being a 5/32. At this time of day the only people still working are those on the west coast..Spruce and Speciality and they only go down to a 5/32.
Could anyone shed light on where #27 plexiglass drill bits can be found or have people used the 5/32?
Many Thanks
Matt Hurley
Chino, CA
RV8 sold...'til next time!
Sonerai 2L 'Restoration'
www.ustool.com
www.hstooling.com
Old 06-16-2006, 07:17 PM
Your local home improvement store will likely carry a variety of Unibits or equivalent. All you need to do is pick the right size. Unibits are plexi safe and will not draw themselves into the work, which is what can cause cracks when using conventional bits.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 06-17-2006, 05:47 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Whelen LED Light Man
Many Thanks
As a fallback you can take any drillbit and run it into concrete. And you now have a nice dull bit that is safe for plexi. DOnt forget to mark it!
Best
Old 06-17-2006, 06:59 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Best
Kahuna - I learn more good real-world stuff from your posts (seriously!)
You have got to be an engineer trained by a grandfather who was a mechanic...the best of both worlds - you know the theory, as well as how it is really done!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-17-2006, 10:06 AM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Clearance holes
Gents,
If the holes drilled in the canopy are for flat head screws then the holes in the canopy are for clearance only. When the screws are thightened down the conical taper on the screw engages the conical shape of the countersunk hole. The interface will center the screw in the hole. Therefore the hole through the canopy plexi is purely for clearance. A number 27 drill is 0.144" diameter, a #6 screw is .138" diameter. That is only .006" clearance. Not very much if you ask me. There is nothing wrong with using a #21 (.159" 5/32" diameter) drill for the clearance holes in the canopy plexiglas.
Food For Thought-
Paul (RV-7)
Old 06-17-2006, 10:57 AM
gmpaul gmpaul is offline
Default Be careful
I have just received a set of plexiglass drill bits from (Wicks). DO NOT USE THEIRS. Even though they are plexiglass bits, they are guaranteed to break your plexiglass. At least they cracked or shattered every piece of test stock I've tried them on. I am using a small unibit. So far, so good.
Old 06-19-2006, 12:25 PM
Thanks Gents for the input. I'll either blunt the end of a regular #27 or run the bit backwards at high speed which was another suggestion.
Matt Hurley
Chino, CA
www.ustool.com
www.hstooling.com
Old 06-19-2006, 12:51 PM
That post about the wick's plexi drill bits breaking has me worried. I bought Avery's. Anybody have any feedback on them. They certainly don't appear to be dull.
Bob Collins
St. Paul, MN.
RV-12iS fuselage
Builder log
Old 06-19-2006, 12:56 PM
Ironflight's Avatar
I used the Avery set Bob, and had no problem. I practiced on scrap first, of course, just to build confidence.
Paul
Paul F. Dye
Old 06-19-2006, 09:50 PM
I'll end up not using plexiglass drill bits. Per the instructions I used a regular #40 drill bit for the holes through the plexiglass and canopy frame...low pressure and high speed through the plexiglass and i'll be using a "blunt" non plexi drill bit #27 to enlarge the holes by "melting" the plastic away.
I'm not going to mention the "c" word but stage one, plexi and frame drilling, went well.
Matt Hurley
Chino, CA
www.ustool.com
www.hstooling.com
