Old 04-13-2012, 07:57 AM
RFazio RFazio is offline
Default Update On My Hard Starting O-360.
I wrote about a week ago on my hard starting O-360. I got a bunch of responces, and went to the airport last weekend and checked my engine. I checked the timing on the mags. I figured if it was an impulse problem, I would see it in wrong impulse firing time. My mags were timed perfect and the impulse fired at 2 degrees after TDC. I checked the plugs and they looked perfect. I decided to change the four plugs on the left, starting, mag just because it was the easiest point to start at. I got myself a set of four tempest plugs and installed them last night. I pulled the plane out of the hanger with the cowl off and tried to start it. She started instantly. I put the cowl back on and went for a little flight. She started instantly again. I'm ordering another set of four plugs, the tempest plugs look real nice by the way. Thanks for the responces guys.
Richard Fazio
LI, NY
N966RV
RV-6 Slider
O-360
FP Wood Prop
