Does anyone know the part numbers for the LEMO style connectors that are slowly becoming the adopted standard for ship-powered ANR headsets?? Of particular interest to me would be metal shelled female panel mount for the airframe; plastic male to wire (preferably pre-molded); and plastic female to wire (again preferably pre-molded).
My plan is to install the panel mount connectors in the airframe; install a 10" long pigtail with a modified male plastic connector (modification being filing/sanding down the locking tangs so that it can be pulled apart with a little force) to my helmet/headset; and then a patch cord about 24" long to hook the two together. This gives me a breakaway feature close to the helmet/headset and no battery packs etc. floating around in the cockpit. I want to first put this in my Super Decathlon and if I like it I'll put it in the Rocket. I'm after connector part numbers if anyone knows them or knows where to find them.
Thanks!!!
Thanks!!!
