Bill_H
For full details/diagnostics of the problem, see here, just posted:
http://www.vansairforce.com/community/showthread.php?t=82782&page=14
The short version is I cranked my engine for the 1st time today. It cranked for 4 SECONDS then stopped. (This was NOT a starting test - bottom plugs were out, no fuel, no ignition.) The AV-50000A power distribution box normally has a fan running full time when the master is on, it stopped when the cranking stopped ad has not come on since with several power cycles. Most (not all) of the other electrical systems have continued to work fine.
This may have been the first non-Van's cranking test using the new avionics and this box power distribution box. Please indicate if you have cranked! 3-25-12
On the plus side, my fuel system pump rate and leak tests went just great!
Bill H.
Bill H.
