frankh
As some of you know I made a engine dehumidifier from two columns of coloured silica gel deissicant (Harbor Freight), a length of ABS pipe and a Petco aquarium pump..9902 I think is the model number... Its for a 60 gallon aquarium.
I have been running this pump for about 3 years and have been very happy with it. It has far more air output than the little tetris pumps.
Well the last couple of months I noticed the dessicant was lasting much longer before changing colour, I pulled the tube off the breather yesterday and found the flow had gone to almost zero.
That pump was a whole 15 bucks so feeling totally cheated I took the pump apart and found there are actually two pumps in one.. The diaprham had ruptured on the side I was using.
So I simply swapped to the other side and plugged it back in. Now of course the diapharam on the other side has been used for just as long so I don't know how long it will last.
It occured however that one could effectively double the life of the pump by removing the unused diaphram when first purschased and keeping it as a spare.
I mean why not.. Not as cheap as making your own earpices for the in ear headsets from foam earplugs but close..
Frank
Frank
