7DeltaLima
OK, I admit it. I seem to have a slow 7A relative to what I see others post as their numbers.
I'm flying a 7A with about 310 hours running a IO360-A1B6 (dual mags) swinging a 3 blade MT prop. The plane flys like a dream, always has. Smooth as can be. Doesn't have a heavy wing, ball centered, flys hands off. My point, the plane appears to be built straight.
I went out one last time tonight and did one more run just hopeing that a miracle had happened and I'd gained 10 knts. before confessing I'm slow.
My numbers tonight and they are consistant with past runs:
trk 90 - gps 169 kts
trk 360 - gps 146 kts
trk 270 - gps 167 kts
trk 180 - gps 192 kts
which using GPS spreadsheet yields 169.3 knots avg speed with .3 std dev. I see others consistently posting above 180 kts avg.,
RPM 2650 MP 24.5 WOT Den Alt 8000 leaned to best power ~13 gph Ind Alt 6810 & baro 29.98 1140lbs empty + 230 me + ~30gal fuel
I've read the posts about the MT 3 blade being 3-5 knts slower and I'd probably trade that for the smoothness.
My questions.... where do I start to try to improve the speeds - what/how do I check. Is it possible/probable it's mostly attributable to the 3 blade prop? What else should I look at? If the fairings were mis-aligned, wouldn't it be indicated by the plane not flying straight? I know there are other RV's running the 3 blade MT, what kind of numbers are you seeing in real life?
Thanks for any suggestions.
Doug
Doug
