Brake issue
Pumped fluid in from bottom brake bleeders. Do not believe there is any air in the system. No air bubbles in transparent lines, and do not believe this is the problem, but will pump more in and suction it out of the firewall reservoir to be sure. This is odd because This has never been an issue for me with this airplane in 800 hours nor on any other I have owed and maintained for over 4000 hours. Will post when I discover the cause. Bill, please post if you find the solution. Rapco rotors look good, and I expected new linings to wear in quickly, but there is noticeable drag when moving plane by hand---not noticeable when taxiing until you touch the rotors. Perhaps these linings are different as they do not seen to wear. Haven't really had time to study this and having cold temps outside when I have had to commute has helped, but it won't stay cold long.
Pistons in the calipers are easy to push in by hand to move the pads away from the rotors relieving the drag, but tapping the brake pedals positions the pads securely against the rotors and they do not loosen much. I have never needed external brake springs before. Obviously, others are using them for this same purpose. Guess I could try this, but fear it may just be masking the problem.
