fstringham7a
RE: High Oil Temp fixed ?
As some may remember I have been working towards getting my ECi IO 360 high oil temps and low oil pressure under control. In this thread I was headed towards a new kicked up oil cooler as part of the solution.
http://www.vansairforce.com/community/showthread.php?t=77317&highlight=hot+oil+temp
New oil cooler from Pacific finally arrived and much time was spent in developing and fabricating a base stand off (stand off #4 cylinder baffle). New oil lines were also purchased. Buttoned it up and did a static run to check for leaks and anyother problems. No Problems so ..... cowled it up the next day, fired it up, and launched with a steady climb while orbiting over the airport to 8500 feet. Temps and pressure were great. I noted that last Oct. 2011 with an OAT of 52 the oil temp was a bit north of 220. At the same OAT and altitude and other engine parameters similar to that October flight the oil temp was just 195 during the test flight. The oil pressure has been very stable in the mid 70's since adding a heavier spring to the oil pressure adjustment.
Second flight yesterday confirmed the test flight numbers.
So it looks good but I still have to wait on that hot SW Utah temps to get here to see if I have really performed some magic?????
I have one more trick up my sleeve when the heat comes if there is still a problem........
http://www.vansairforce.com/community/showthread.php?t=73164
Alot of thanks to all you VAF engine gurus for advice. Wayne at Pacific cooler was very helpful. Tom at TS Flightlines was just great and went way out of his way to make sure my hoses were correct in all ways along with fitting advice. As a foot note I have made my own hoses in the past but thought I would give Tom a try.......for about the same $$ as I would have paid to make my own I now have some hoses that I really feel comfortable with. Finally the usual 1L8 airport crew helping me to get the job done.
