I am working on the steps for my 7A and am at the point of priming and riveting. The steps fit flush except at the lower aft part of the plate. I have done some trimming and bending, but still have a small gap that seems no amount of trimming or bending will eliminate. I think I am going to put some pro-seal on the step plate as I install it to help seal this gap(only visible from underneath looking up). How should I prepare the step plate and fuselage skin to accept the pro-seal. I originally was going to just prime everything and rivet away, but with the pro-seal I'm not sure on the prep and priming. I want the primer protection, but need the gap bridging of the pro-seal.
Can it be both rattle-can primed and prosealed? Or will the proseal react bad with the primer?
Thanks for your advice!
Chad
Boulder City, Nevada
Chad
