RVbySDI
Below is text I copied from a post I made to the Anti Splat "Nose Job" a review thread.
I am posting my comments from that thread as a new thread here because of my discovery that my nose gear wheel pant had come into contact with the runway sometime in the past. I was shocked to see marks on my wheel pant after removing it to install the Anti Splat Nose Job. My comments below and subsequent pictures are verbatum from the above mentioned thread. I felt it important to repost here as I wanted to make sure others who may not be following the Nose Job thread can be aware of the possibility of having your nose wheel pant come into contact with the ground even if you may not be aware of it doing so.
Here is an excerpt of my original post from here:
I received my Nose Job on my door step on Thursday when I arrived home from work. However, it would have to wait a while before installation. We had plans to fly to Petit Jean first thing Friday morning. My wife and I flew out to Arkansas and had a wonderful time. We had plans to stay through Sunday before coming home. As it turns out, the weather was not going to cooperate for a flight home Sunday so we ended up leaving Saturday afternoon instead. This left me with time on my hands Sunday. The sun was out at the airport and it turned out to be a warm day. So out I go to install the Nose Job.
Here is my report with pictures of the installation. Ok, before we go any further I have to make comments on this first photo.
This was quite a shock when I pulled the front nose pant off of the gear!
What the. . .! Look at those groove marks! Those are directly underneath the big nut in front of the yoke. Now I live on a grass strip and at least one landing on every trip involves landing on grass. Well, I am going to tell you, no grass I have ever landed on is tough enough to put those kind of grooves in fiberglass. No, those were caused by some asphalt somewhere, sometime. I cannot be sure when exactly.
When would this have happened? I have no memory of any landings that might have caused this. No taxi incidents that I am aware of. Hmmm. Not cool! We picked the plane up from Grady on January 1, 2011 so the paint on this wheel pant is not even a year old. The best time frame I can think of would be that this happened sometime between the conditional inspection (July 20th) and Sunday (November 6th). Sometime the nose gear oscillated enough to allow the nose gear pant to come into contact with a hard surface. If you look closely you can see black tar in between some of the grooves. Yes, indeed, this fiberglass was rubbed up against asphalt sometime, but for the life of me, I cannot imagine when this would have occurred.
Now I have commented to several individuals in the past about the landing technique and taxi technique involved in maneuvering our A models on the ground. I have always felt it very important to keep the nose gear off the ground as long as possible when touching down and to make a point to keep the stick rubbing against my belt buckle whenever the airplane is on the ground. I have always landed on the mains and held the stick back until the nose just would not stay up any longer. In my opinion, this is the only way to land these A model airplanes. And it is what I have always done.
Given this I am somewhat taken aback by this discovery. Having done exactly as described above at all times, I find this wheel pant has still come into contact with the ground at some time. This gives great pause for thought.
So, for all of you guys out there flying without wheel pants on your A model nose gear pay heed to this. Here is pictorial evidence of how that fiberglass may save your bacon sometime. In my case, I didn't even know it had happened!
Live Long and Prosper!
