RVG8tor
I was looking at my cowl today and noticed that the angle of the scoop opening and the front of the cowl are off. I laid levels on the front and over the scoop, it seems neither is square with the fuselage. I am pretty sure the front of the cowl should have this angle as the engine is mounted offset and the top and bottom section of the cowl seem to have the same angle. I could not find anything in the plans that tells you the cowl will fit like this, all of the drawings for the cowling show everything parallel and square and very symmetric.
The scoop seems to have been glassed in later and I am not sure the opening in the scoop should have this angle. I wonder what you others have found, should the scoop be centered and square here or is there a purpose to the angle. Trying to decide if I have a defective cowl.
Thanks for any help
Cheers
Thanks for any help
Cheers
