I have been trying to localize a problem with my tip-up canopy for a couple of months now... The front corners of the canopy frame "lift" in flight, making my attempts at weatherstripping the join between the canopy and the cockpit sidewall useless. Sitting on the ground, I could see about 1/4" gap between the bottom rail of the canopy and the top of the cockpit sidewall. In flight, that gap grew to somewhere between 1/2" and 5/8" on my last flight. This gap is much worse on the pilot's side, the passenger side the gap is only 1/8 to 3/16" in flight, and none on the ground.
On shutdown after my last flight, when I opened the canopy, I found the culprit. The weld between the hinge arm and the front canopy bow is cracked, almost all the way through on the pilot's side, and more than half-way through on the passenger side. And on top of that, the C-channel that it rivets to is also cracked.
If i've done this right, here's a picture. I've posted more on my Picasa site.
It seems odd to me that the joint is designed in this way. The curved part of the canopy hinge requires cutting out the lower flange from the canopy bow, which seriously compromises the load-bearing capability of that piece... It forces the loads directly onto the weld. It's almost *guaranteed* to fail, due to its design. Even though i'm religiously careful with the canopy when opening/closing, it still flops around a bit so this has probably been building over the last year i've owned the plane.
I'll email Vans on Tuesday and get their input as well, but I just wanted to see if anyone else has seen this or if anyone has any suggestions. I tried both Google and the search here on VAF but found not one article referencing this. Surely i'm not the first?
So far, the best sequence I and my fellow local RV'ers have come up with seems to be:
1. Remove front trim piece (thankfully, screwed in place)
2. Drill out pop-rivets holding plexiglas to the rear canopy bow
3. Remove screws holding plexiglas to the rest of the canopy frame
4. Have the weld Tig welded (the frame is aluminium)
5. Have the cracks in the bow also Tig welded
6. Optionally, add a plate to the front of the bow, bolted in place, to reduce the stress on that weld
