157 hours after first flight and I've just about completed my first RV8 condition inspection.
First Impressions: Fairly easy to maintain and inspect compared to other planes I've built and owned.
Things I'd do different if still building knowing what I know now:
1. Add an inspection cover to the aft baggage shelf to avoid having to remove all those screws to inspect the elevator linkages and tail cone (especially un-fun in the Florida August heat)
2. Add 1/4" u-channel rubber along the rear seat back edge to prevent scratching the paint along the bulkhead and the canopy handle - I just added this today.
3. Add inspection covers to the center section of the fwd baggage compartment for quick and easy access to the rudder pedals and brake assembly. Removing all the screws in the far aft corner area wasn't fun - I did this already.
4. Make the landing gear tower mod for easier access to the landing gear bolts. I still haven't done this and want to punch myself in the stomach over it.
5. Don't forget to run the fuel lines dry after you shut-off the fuel valve when preparing to remove and inspect the fuel filter - DOH! Have plenty of rags and paper towels in the cockpit if you do.
6. Use the shortest screws possible when securing access panels (1 or 2 threads showing is good). For some reason I had screws in most of my panels which were about 1/4 too long. All this does is make for a ton of extra work.
I spent the entire month of August going through the inspection focussing on one section at a time and never taking the plane out of service. I continued flying between inspections. I was able to still have fun and never had trouble seeing the trees through the forest (or something like that).
The only issue I found was a little wear on the both the inboard and outboard wheel spacers which I'm a little perplexed about to be honest.
my .02
my .02
