Go Back   VAF Forums > Model Specific > RV-3
Old 08-27-2011, 08:13 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default RV-3: Stuffing the Cheeks
It pays to look at other people’s RV’s at Fly-ins….you find so many good ideas that you can steal! One of the things that I have planning to do for some time (ever since we saw Shawn Scott's very nice RV-4 which is loaded with clever ideas) was to build hatches in to the cheek cowl extensions and use them both for stowage and as access points for the cowl side pins. The cheeks are usually just empty space, but can easily store tie-down ropes, a few tools, a couple of rags, oil funnels – all of the things that normally bounce around the baggage compartments on most RV’s.
Taking a cue from several recent RV-3 builders, we discarded the sheet metal parts supplied in the kit and built fiberglass extensions over male foam molds. Once we had rough them out and done some initial filling to get the surface where we wanted it (relative to the cowl), we finished up the cowl fastener flanges and made the whole external structure rigid. I then played around with hatch sizes using some heavy card-stock. While my initial plan was to build a hatch large enough to insert a quart bottle of oil, I quickly realized that with the small size of the RV-3 cheeks, I was going to have to make the doors awfully large in order to get the bottle inside – the hatch would have to be close to the side profile of the bottle, since the cheek is fairly shallow. I settled on an opening “That Looked About Right” at approximately 5”x5” – the same as the oil door.
After laying it out on the cheek with marker, I cut the hatch out with a thin cutting wheel on a Dremel tool, carving the corners with a very small diameter die grinder bit on the same Dremel – this minimized the kerf losses. I used some 0.032” Alclad to form the flanges, drilling it to the inside starting from one corner to allow it to lay where it wanted on the inside of the tapering conic surface – I then straightened up the lines after clecoing it on using a sanding disk on the angle grinder. Piano hinge on the bottom edge could have been replaced with a hidden hinge if I wanted to take that much extra time, but it would also have taken up some useful storage space, so I went with the simple option.
Latches will be two Hartwell’s per door – one forward, one aft. When I get those installed, I’ll add a glass stiffener rib to the door to make sure it doesn’t bulge out into the flow in flight.
These little storage pods should be really nice in such a small airplane – they don’t add but a couple of ounces, and should keep the baggage compartment clean and organized – at least that’s the plan!
The cut-out – done with a thin cutting wheel on a Dremel:
Door Open (clecoed in place) – note aluminum flange:
Door Closed (needs finish trimming to make the gap neat of course) – need to add latches:
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-27-2011, 08:50 AM
FredMagare FredMagare is offline
NICE idea!
Fred Magare
GySgt, USMC (Ret.)
Frederic.magare "at" gmail.com
RV-9A SB Fuselage / Finish Kit Ordered
Old 08-27-2011, 03:37 PM
gasman gasman is offline
Paul, was one mold used both sides? What are you going to do with your mold(s)?
Also, depending on if you have already used the space, you could "box" into the fuse for deeper storage.............
Old 08-27-2011, 04:20 PM
Ironflight's Avatar
The molds were male plugs built up out of foam insulation sheets - one for each side (the cowl is not perfectly symmetrical) - and they didn't really survive intact.
I don't think I'd want to carve into the monocoque fuselage at that pint - and at any rate, it woudl cut into legroom (yes, it is a tiny airplane!).
Paul
Paul F. Dye
Old 08-27-2011, 05:52 PM
Snowflake's Avatar
With the cheeks stuffed like that, you might need to christen the RV-3B "Chipmunk"... But I guess that's already been used by mister deHavilland. Maybe "Squirrel"? They always seem to be darting about the yard with something in their cheeks...
Rob Prior
Old 08-28-2011, 08:10 AM
jjconstant's Avatar
jjconstant jjconstant is offline
"flying" squirrel...Rocky. Which would make the Val Bullwinkle
Jeremy
Old 08-28-2011, 08:37 AM
humptybump's Avatar
humptybump humptybump is online now
Jeremy - not fair! I wanted to throw out the Rocky & Bullwinkle joke!
Paul - exceptional work as always. It's little things like this that make me want to build. It's the big things that remind me otherwise :-)
- Glen, ESVA
Old 08-28-2011, 08:57 AM
Mel's Avatar
Mel Mel is offline
Default Nope!
It simply HAS to be named "ALVIN"!
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 08-28-2011, 07:52 PM
Louise Hose's Avatar
Jeremy
Hmm. Rocky. Good name for a geologist's airplane!
RV-6 “Mikey” (purchased flying) – Garmin test platform (G3X Touch, GS28 autopilot servos, GTN650 GPS/Nav/Comm,
Old 08-28-2011, 08:09 PM
Scream's Avatar
Scream Scream is offline
Default Kerf Loss
I enjoy posts that force me to google things I used to know. Kerf loss got me this time. The things I have forgotten...
(Also Hartwell latches. $148.95 each? Ouch.)
Tail Feathers complete; down for a 2 year hiatus...
