drewhottub
On the RV10 Plans Section 14 pg 04, I'm finally finding myself being forced to learn more about aircraft construction, than just sheetmetal working / riveting!
I'm wondering if some of you VAF users, would be willing to just tell me explicitely, what holes I ought to drill through my wing ribs, if I told you that I wanted a Cross Country Capable, IFR capable RV-10.
Essentially here is my requirements list:
LED Nav/Strobe Wiring Runs.
HID Landing/Taxi Lights Wiring Runs
Auto Pilot Servo Wiring Runs
Angle of Attack Wiring Runs
Pitot Tubing Runs
Pitot Tube Heat Wiring Runs
Flap Motor Wiring Runs
Fuel Tank floats Wiring Runs
And anything else that I can't think of, that you think I ought to add.
(Perhaps from this requirements list you might suggest all of the necessary wire run holes to drill.)
Note: Here are a couple of pictures to help you understand what I'm asking, a little bit more clearly:
Direct link allows you to zoom in and out ---> https://picasaweb.google.com/lh/photo/zdeLlvoutpLj0_TfNTMfCBas8ZD2SvsSugjWQRt7ZyM?feat=directlink
https://lh3.googleusercontent.com/-sgJz-6Jg3ts/TlKgBw29XgI/AAAAAAAAAdY/jmGtLmhXE8g/s1280/rv10_plans_sec14-pg04%252520with%252520ed%252520godfrey%252520mods%252520and%252520Andrew%252520Comments.jpg[IMG]
Direct link allows you to zoom in and out ---> [url]https://picasaweb.google.com/lh/photo/vqLh8d43Ngf1HHobxvC9khas8ZD2SvsSugjWQRt7ZyM?feat=directlink[/url]
[IMG]https://lh6.googleusercontent.com/-faSe9bMxiwY/TlKPRL_znMI/AAAAAAAAAc4/8ex5sOyN584/s1024/RV10_Plans_sec14-pg04%252520with%252520Questions.JPG[IMG]
Best Regards,
Andrew
Pitot Tubing Runs
Best Regards,
Andrew
