Old 07-08-2011, 04:49 PM
JFRV8 JFRV8 is offline
Default RV-8 W&B Spreadsheet
Here is a Weight & Balance Spreadsheet I generated. It is in Excel and can be edited for you airplane's numbers (just turn Protection Off).
If you want a copy, send me a PM.
Old 07-10-2011, 02:03 PM
Toobuilder's Avatar
Nice! I also developed a spreadsheet (but yours is less "busy").
In mine, the grey boxes are editable, and the results update through the excel magic. It also updates the aerobatic, normal, or out of limits based on green, yellow or red. In the example shown, I am only within aerobatic weigh limits at near zero fuel (green), but still outside the aerobatic CG even at empty (yellow).
I did notice a difference in the arm for your wheels. I measured 69.75 to your 68, (not a huge deal) but significantly, I get 251.625 to your 240 - a whopping difference! Did you measure in the 3 point or level attitude? If we have essentially the same airplane, your forward bias looks like it was measured on the floor in a 3 point. Plugging in your tailwheel arm number (240) moves my CG forward a half inch. I guess I better jack mine up and re-do the measurements to make sure.
Michael Robinson
______________
Harmon Rocket II -SDS EFI - Flying
RV-8 - Flying
1984 L39C - flyable, available for sale
Old 07-11-2011, 07:18 AM
Alan Carroll's Avatar
Alan Carroll Alan Carroll is offline
Originally Posted by Toobuilder View Post
Nice!
Michael - I have 68.75" for my mains. If apply this number to your weights it moves the aircraft CG forward about an inch. Perhaps these measurements are related to your mysterious aft CG change following rebuild?
Alan Carroll
RV-8 N12AC
Old 07-11-2011, 11:57 AM
humptybump's Avatar
Default iPhone app
For iPhone users (and probably Android), I wrote a web app - http://53vg.com/wb
If you bookmark it to you smatphone's home screen, it caches itself and no longer requires a data connection. It also remembers the values from your last calculation so once you enter you fixed values, they "stick". I wanted something so convenient, I'd use it for every trip and every passenger.
- Glen, ESVA
Old 07-11-2011, 12:21 PM
Toobuilder's Avatar
Thanks for the data point Alan.
I did keep the same measuremnts for both before and after, so that should have remained a constant.
Question - you measured in the "level" attitude, or 3 point? Also, what was your tailwheel arm?
I will certainly be measuring again!
Michael Robinson
______________
RV-8 - Flying
Old 07-11-2011, 04:29 PM
bird's Avatar
bird bird is offline
Default yes
I would like a copy please. Thanks in advance. Looks very good.
tcb328@suddenlink.net
tim
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 07-11-2011, 04:51 PM
APACHE 56 APACHE 56 is offline
Default Me too...
Please send me a copy Jon.
donstiver@earthlink.net
Don
Don Stiver
RV8 "Little Pill" N6371S, Merritt Island, Fl.
BPE IO-390, Dual P-mag, MT 3-blade, AFP system
Steen Skybolt: Sold
Old 07-11-2011, 04:53 PM
Its been a while but I'm pretty sure it was with longerons level. I have 251 for the tailwheel.
Alan Carroll
RV-8 N12AC
Old 07-13-2011, 07:13 PM
Default Change the N Number
Thanks everyone for the responses on the spreadsheet.
You can change the N number in the graphic since it is in a textbox. Just turn Protection off first so you can select the text box.
The weights and arms are based on typical numbers from other RV 8's. I have not measured and weighed mine yet.
Jonathan
Old 07-19-2011, 09:21 PM
HawkinSF HawkinSF is offline
Default Love a copy...
Sure would like a copy also... Thank you!
J. Hawkins
hawk@gofarmers.com
878Z RV-8
