albertaflyer
Hi all,
Just wondering where the best place is to support the plane to change main gear tires? Also, what make of tire do most use. I was also going to check to see if there is any camber on the wheels I did notice that all the wear has been on the outside of the tire on both sides but more so on the passenger side. Should they have a little toe in or just parallel? Any info appreciated! Thanks in advance!
