Go Back   VAF Forums > Main > Reviews
Old 06-24-2011, 04:37 PM
bpattonsoa bpattonsoa is offline
Default Proxxon vs Dremel
Having burned out several Dremel's over the years, I now have a Proxxon, German made, expensive, but a very high quality tool. (Cheap considering how many Dremel's I have owned)
http://www.proxxontools.com/store/pc...0&idproduct=10
Does not run as fast as the Dremel, but runs all day and stays cool. Ball bearings, 20,000 rpm, long cord, great storage case.
Bruce Patton
RV-6A flying since 1999
RV-10 in the very near future!
Moving to Independence Airpark next month!
Old 06-24-2011, 05:02 PM
roee roee is offline
Default ... vs. el cheapo Harbor Freight special
Same problem, different solution. I also got tired of paying top dollar to replace burnt out Dremel tools every couple of years. But I went the other way.
When my last Dremel tool gave up the ghost, I bought some cheap Chinese knock off from Harbor Freight. Cost about $10. Not sure about max RPM, definitely lower than Dremel's. But high enough for everything I've ever used it for, and I've used it with various types of bits on both composites and aluminum. I've had it for at least a year at this point, with lots of use and no signs of deterioration. And even if it dies tomorrow, replacing it every year or two at $10 a pop is a lot more palatable than at $100+.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 06-24-2011, 05:43 PM
humptybump's Avatar
Default Rot zip + flex cable
After burning out my Dremel. I built a wooded cradle for a rot zip and attached the flex cable from the dremel. Works great and is indestructible. Also very affordable.
- Glen, ESVA
Old 06-24-2011, 07:22 PM
rzbill's Avatar
rzbill rzbill is offline
Default I went with air
I agree with the Dremel burnouts. I found an air powered pencil grinder at Home Depot (sale table) for 20 bucks about 7 years ago. Still going strong. I'll replace it with air again if it fails.
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 690hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 06-25-2011, 01:47 AM
Allan Christer Allan Christer is offline
I've had one Dremel burn out, and I found out that if you return it to Dremel for repair, most times they will send you a new one. Standard 'repair' costs are about $30. Check their web page out. i sent back an old type Dremel, and received, for their repair charge, a brand new, latest model.
Living in Germany, I have also had experience with Proxxon, and frankly, have not been impressed. Although I do not have their Dremel equivalent, I do have their jigsaw, and find it very cheap and disappointing, and at a very high cost. Their other equipment in the HD equivalent here seems more to be based towards the model/handicrafts market, and is very expensive.
________________________________
Allan
Old 06-25-2011, 01:52 AM
Wow. Just checked out a couple of discount stores for the Proxxon and it is about $115 plus postage.... specs show it is a nice machine, but double the cost of a Dremel.
I guess you pay your money and takes your choice. However, the posting on the rotary zip tool sounds interesting. Can these take the same kind of collet/chuck that the Dremel/Proxxon have?
Allan
Old 06-25-2011, 04:57 AM
humptybump's Avatar
In my case, the dremel I had that burned out, had the long flexible-cable. So "yes" all of the dremel tools fit because the flexible-cable is already dremel. It's not as portable as a cordless dremel but for bench work it's great. I recently used it to cut a new opening in my panel for an addition to the radio stack.
- Glen, ESVA
Old 06-25-2011, 08:14 AM
flydjd's Avatar
flydjd flydjd is offline
Default Q
Allan
Hi Allan,
I am also in Germany and have an old Dremel (well out of warranty) that now only runs at one speed !
Was yours within warranty ?
Also I can't see from their webpage any details about the repair option you used. Did you take it back to the shop you bought it from or send it direct for repair within Germany ?
I also have other Dremel tools like the flexi cable and found that very useful so don't want to change make.
David
David J. D.
RV 7A QB (but possibly slowest builder in Europe !)
Hannover,
Germany
VAF # 776
Old 06-25-2011, 10:54 AM
TThurston TThurston is offline
Default What for?
I'm not yet a builder, but have put together the practice airfoil kit and the toolbox, and a few other little projects. I've looked at Dremels in the store and wondered what exactly RV builders use them for.
Please enlighten me.
Old 06-25-2011, 05:57 PM
tomwebster's Avatar
tomwebster tomwebster is offline
Off the top of my head, some of my Dremmel uses were:
All the first rough cuts on my slider 7 canopy
(saw a demo at Vans tent at OSH from the
canopy supplier doing the separation first cut
with a Dremmel)
all hinge cutting (my band saw does not like the hinge rod)
all fiberglas cutting and shaping
(wheel pants, gear legs, fairings, wing and empenage tips)
all square instrument panel cutouts
(switches, fuse panel, hobbs, ELT-control, etc.)
I bought a cordless Dremmel about half way
through the build and prefer it to the corded model.
I usually use the fiber reinforced disks, especially on steel.
I personally have better control of the cut which saves on
filing and finishing the edges.
Tom
Tom Webster (Chox)
VAF-134
Columbus, Ohio
Luscombe 8A/E (sold after 35 years)
RV-7A N462TW (315 hours)
CX4 (under construction)
Friends of the RV-1 http://www.rv-1.org/
