N8RV
When my used Airborne boost pump went belly-up at about 140 hours and attempts to revive it were fruitless, I decided to bite the bullet and just buy a new fuel pump. My choices were the one that Van's sells, the Andair or the EFII pump.
I read most of the info and reviews here on VAF before making my decision, and decided to buy the EFII. When it arrived, I had immediate concerns about mounting it where my old Airborne pump was located, between the front of the gear leg tower and the firewall.
There is only 15" of room there (sorry for the dirt -- remnants of trying to resuscitate the old pump) ...
I made a bracket from some heavy aluminum plate and used the existing mounts in the longeron where I had previously mounted the old pump ...
But, when I made minimum-radius bends in tubing to attach to the straight AN fittings that come attached to the pump module, it used up 14.75" of the available space ...
That meant that I needed to either make a real spaghetti-mess of tubing with a bunch of bends, or turn the pump around and run tubing from the fuel selector valve to the FORE end of the module, and loop another long run from the module to the fitting on the firewall.
I wasn't too happy with that prospect, but couldn't think of any other way to do it, and I'd used up a lot of aluminum tubing trying to make shorter bends and make it work.
Finally, an e-mail to Robert Paisley at EFII did the trick. I suggested swapping the straight fittings for a couple of 90-degree fittings, which freed up a LOT of room. The overall length of the module with straight fittings and 90-degree bent tubing went from 14.75" to only 11" with the 90-degree fittings ...
Here's a picture of the 90-degree fitting -- note that it has an O-ring seal and a lock nut, so it can be clocked in any direction ...
Once mounted with the new 90-degree fittings, plumbing it was a comparative breeze. I did still have to make a loop to connect to the firewall fitting, but the line to the valve was straightforward ...
I'm sure that someone making a new installation could design a better way to install the EFII boost pump module, but since crawling through the baggage door was somewhat limiting, I was happy with the compromise.
Robert was a gem to work with, responding immediately to my queries for help. The pump seems to work as advertised, once I got it primed by starting the engine and letting the engine-driven pump do the hard work.
I checked the fuel flow and it pumped out 46 gallons/hr, plenty for my IO-360. Fuel pressure is solid, and the unit is relatively quiet.
Oh, and if anyone is wondering where the supplied fuel filter is ... I have filters mounted in the wing roots, prior to fuel reaching the selector valve.
Hope that helps.
Hope that helps.
