Fly higher
vanplane said:
When the f/p was pitched up enough to handle those fast cruise speeds, there wasn't much left for takeoff, especially at high density altitudes or with big loads (the one or two times I flew it with both, acceleration was pretty anemic). A simple two position prop would have solved the problem, but I don't know where you'd find one.
Sure 115HP, 116Hp or 118HP is plenty. No doubt. I think the point everyone is making is the higher HP solves the fixed pitch prop dilemma. With a cruise prop and greater HP, you will have as good or better takeoff and climb as a 118HP RV-9 with a climb prop. As you point out there are no fixed props with two positions. There are ground adjustable props, but I am opinionated, the ones out there now look like they are made for ultra lights. However ground adjustable props does not solve the in flight problem.
There are electric props but, I am not for that expensive option. More HP with a fixed prop is a much easier and cheaper solution to get both good takeoff/climb and cruise performance with a fixed prop.
I don't think there is any doubt 118 HP is plenty. However your point about the excellent high altitude cruise capabilities of the RV-9 wing remindes me it would be enhanced with more HP. With "excess" sea level HP, you could fly even higher improving economy. I am not a fan of sucking O2 thru a mask, but I am really talking about flying at altitudes say between 8,500 and 12,500 feet at gross with some "authority". RV's (or any plane including a B737/B757/B767) at service ceiling is a mushy uncomfortable affair.
If you LOOK at 118 HP RV-9A ceiling at gross it is only 14,500 feet. You need to know that is not a good efficient altitude. That's an altitude you can make 100 ft/min climb, may be. It is kind of marginal. You need to subtract about 6,000 feet or more off the MAX service ceiling to get a "reasonable" cruise ceiling. Looking at 118HP at gross weight you will be really maxed out at 8,500 feet. What if its real HOT and you're in mountainous areas. Any one flying distance in and around the west cost should consider the higher HP. For most a cruise of 8,500 feet is OK, but it would be nice to have climb capability to easily go to 12,500, even at gross. If flying solo over the mid west, the 118HP is plenty.
That is what the extra 42 HP gets you, high altitude climb and cruise capacity. If you are going to be doing fully loaded coast to coast flying or flying around the western side of the US, I think most builders are better service by the O320. It's not for speed it's for payload hauling capacity.
Sometimes HP can be a safety assist. Allowing you to fly over weather, terrain and takeoff and climb faster, even with high density altitude. With that said a O235 is a fine engine and a RV-9 with either either engine is a fine airplane. If I was into the -9 and found a O235 cheap, heck yea I would consider buying and installing it. G
