Go Back   VAF Forums > Main > Safety
Old 05-12-2011, 07:44 AM
Jimzim Jimzim is offline
Default Firewall sealant and Fire Safety
Can anyone recommend a source for a firewall sealant that can easily be mixed/dispensed in small quantities? Each time I need a dab, I can use Pro Seal but the shelf life is short and I can't find a small quantity at a reasonable price. What else might be out there? The high temp RTV is only rated to 600 degrees F.
Thanks in advance! Jim
Old 05-12-2011, 07:47 AM
benbell4140 benbell4140 is offline
I have used expired proseal on various things. I wouldn't use it in a fuel tank but I used it on my firewall.
Ben Bell
RV8 (Louisiana)
Working on finishing kit
Old 05-12-2011, 07:48 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Keep your ProSeal in the fridge .... you do have a beer fridge in the shop, don't you? It will last for years. No worries using it for jobs like this.
Vince
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold
Old 05-12-2011, 08:02 AM
DGlaeser DGlaeser is offline
Default Firewall sealant...
Pro Seal (for fuel tanks) is NOT a good firewall sealant! I don't know what temp it's good for, but it's nowhere near 600F, and it burns.
Vans sells a firewall sealant, but it's not cheap and has to be mixed as well (maybe that's the stuff you are talking about). I used it to seal my firewall and all the openings I could at that time. The rest got the Hi-Temp RTV.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport & EIS4000, 300XL, SL30, ADI Pilot II, PMA6000, AK950L, GT320
Old 05-12-2011, 08:04 AM
DanH's Avatar
DanH DanH is offline
3M Fire Barrier 2000:
http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-12-2011, 08:13 AM
My plans from vans said use (fuel tank sealant) on skins to seal to firewall flange.
Ben Bell
RV8 (Louisiana)
Old 05-12-2011, 08:20 AM
Andrew Sego Andrew Sego is offline
This is what I used. Flamemaster CS1900 Firewall Sealant. Available from several different vendors.
Old 05-12-2011, 08:30 AM
Vern's Avatar
Vern Vern is offline
Default Home Depot sells it in the tube
Vern Darley
RV-6A N680V / RV-10QB N353RV
Luscombe 8E
Hatz Biplane
Falcon RV Squadron
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 05-12-2011, 11:26 AM
DrHolling DrHolling is offline
Which one?
Old 05-12-2011, 11:37 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by DrHolling View Post
Which one?
The 3M product that Dan cited is what I bought at Home Depot - expensive tube, but if it lives up to its claims, it should be well worth it! I used it for the firewall recess on the -3, and will be using it for the rest of the -3 firewall sealing job as well. Much better high temp properties than Red RTV, FAR better than pro-seal.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
