4 working and 1 failed (20% failure rate) / Why I started the poll Part 1
It has been about 6 days since I started the poll. My Andair pump did not work out of the box. I see that there are four (4) flying and are working. Looks like a 20% failure rate as of this small sampling. I only tested my pump because of hear say that someones pump did not work. I hear that they sent it back and got their money back. I do believe that Andair tested the pump before shipping it. I could smell Stoddard Solvent when I connected it to a 100LL fuel source.
My pump was purchased through the VAF group buy. I do not need the pump right away but have a 360 rebuild project in my hangar to install in my flying RV-6 in the future. (The sooner the better.)
I did not want to pay to ship the pump back and then get a new one. Being an Electrical Engineer during my day job, I am also an FAA A&P, and DAR. I did not see a problem with opening up the pump. Maybe it can be fixed. All of us are human after all and do make mistekes. (intentional miss-spelling)
Seeing what is inside the pump and the reason that it failed, I now know that I do not want this pump flying on my airplane. IMHO, it is not a good enough pump to use on aircraft. IF I am not able to get my money back from Andair, I will NOT sell it to someone for use on an aircraft as I do not like the design. (I am not a mechanical design engineer so my advice may only be worth what you are paying for it.)
I emailed Andair about the pump. Their response and my email to them follows pasted in but first I took a look at this YouTube
video.
Note: I am editing the email addresses to slow down spammer.
--- insert ---
Dear Gary,
We would not send out a unit that had not been tested and checked, however any amount of testing and checking sometimes cannot discover some of the problems that manifest themselves in production. I am not going to give lots of excuses to you as you are a professional engineer, but just to say mistakes happen and we all try to learn from them.
In your case, we, here at the factory are very concerned that you have experienced this and we will do anything and everything to bring this to a happy conclusion.
We would welcome the opportunity to offer you a replacement, if you were to agree to this we would pay the return shipping or if you are at Oshkosh this year take it back from you there.
There are a few answers to you fears.
1. The lack of priming: The pump was designed to prime at least to 3 metres and this is normal for all our pumps. The pump you have, that is not priming at all could been caused by two factors, one the "O" ring on one of the check valves becoming dislodged, (and I think you found this to be happening on one of the check valves when you disassembled the unit) this would certainly prevent priming as the return spring would not have the force to close the shuttle against a dislodged "O"ring. The second is remiss on our part through not carrying out any preserving process so the internal parts would be in lubricated condition for start-up.
2. Your concern regarding the very small pin on the outer check valve holder this is purely a location pin for position it has no condition in bearing or torque it is purely position.
3. The lack of flow and pressure, this again is a probable issue with the dislodged "O" ring.
The conclusions: In the months since the VAF sale we have been developing the pump further, it now has the controller integrated on a saddle on top of the main body, some internal parts have been redesigned to reduce noise and to improve performance. the "O" rings on the check valves have now a groove that they sit in and the possibility of sliding down the shuttle barrel has been eliminated .
I hope the explanation above goes someway in helping explain how this may have occurred .
Kind Regards
Andy Phillips
Andair Ltd
PS. You may or maynot know that we test all or products on our own aircraft. Our early pumps were tested on our RV6 and the pump setup you have is running on our RV7 both running well.
Email:
andair at andair dot co dot uk
Web:
www.andair.co.uk
----- Original Message ----- From: "Gary A. Sobek"
Gary at RVdar dot com
To:
Pump at andair dot co dot uk;
Sent: Tuesday, May 03, 2011 6:16 AM
Subject: Boost Pump
Dear Sir:
I purchased one of your boost pumps as part of the VAF deal. I purchased your pump sight unseen based on the quality of the valves I have seen with your name on.
I tested the pump and it would not self prime. I had to prime it to get it to pump. I did not run it more than 45 seconds without being primed. I used 100LL as the fuel I was attempting to pump. The pump did not appear to pump enough fuel to keep a Lycoming 360 running at full power with only the boost pump supplying fuel.
Since you are in England and I am in the US, I did not want to send the pump back if it could be fixed. More investigation was conducted.
Here is the link to info on what was found.
http://www.youtube.com/watch?v=AocoUdGnyGw
This is not a pump that I would use in an aircraft. The pump is not good enough for use in my aircraft. I hope that you are not going to tell me that I cannot get a refund because the pump was disassembled and discovered not to be suitable for Aircraft use.
I am an FAA licensed A&P, DAR, and am a Engineer by training. The aircraft that I was hoping to install the pump in is an RV-6 that I built and have been flying for almost 2,500 hours. I am presently flying with an O-320 but have an IO-360 sitting in my hangar. The pump was going to be used with the engine swap out.
I am not happy with the discovery that the pump is not suitable for aircraft use but I am very happy that I found out before it was installed.
I am very concerned about the quality of your boost pump. A friend died in a fuel injected aircraft like mine when his engine quit on takeoff and his aircraft flipped over when it landed off the paved runway. His neck was broken when the aircraft flipped over. The NTSB investigation found vapor lock as the cause of engine stoppage. The engine was ran during the NTSB investigation and the boost pump was found not to operate. The lesson that I learned from his accident is that the boost pump must work to help prevent vapor lock of the hot engine on a hot day.
Respectfully,
Gary A. Sobek
When once you have tasted flight,
you will forever walk the earth with your eyes turned skyward,
for there you have been, and there you will always long to return.
- Leonardo da Vinci
--- end insert ---
See next message for part II
