After getting Junior on his gear last weekend, we did a little cleanup work on empennage fiberglass, then had to do some hangar cleanup to host the Houston RV builders on Saturday. That meant that this morning, we got to the workshop with no ?in progress? projects to work on ? everything had been put away. What to do, what to do?.i guess we have this engine, a hoist, and a clear path between the fuselage and the back door ? might as well see just how tight this installation is going to be!
Louise had done her homework and read up on engine installation, but I warned her that we weren?t going to be putting it on the mount today ? for one thing, we hadn?t gathered the necessary tail weights, and for another, we didn?t have any oil cooler fittings for the accessory case. Knowing just how tight the firewall/engine interface is going to be, (I used to own a Yankee, and former Grumman owners will know what tight means!) I am planning that EVERYTHING that goes on the back of the engine needs to be there before we hang it for good.
Sure enough, we learned stuff right from the start. Like we were reminded that this is an RV-3?there ARE no firewall forward kits, instructions, or drawings. I had to dig out the RV-8 firewall forward drawings and start making a list of fittings we?ll need for the fuel and oil plumbing. That was the easy part ? next came the fitting (like a slow, stabilized approach). We learned right away that the oil filter had to come off:
The good news was the Randy Lervold?s pictures were right ? the recess was in the correct spot for the prop governor. He was also right that the standard cable mounting bracket doesn?t work. Add that to the modification list?
Next, the oil filter adapter ? going to need that 1.4? spacer that Randy mentioned!
We used to ask ?how did people build these things before the Internet came along?!? Now I ask, ?How did we build these things before the digital camera?!? Invaluable for capturing data from a fitting session, here, we see an image that will help me fabricate the necessary cable bracket for the prop governor:
Louise was not idle by any means during the fitting session ? she took this picture after saying ?I think we?re going to need a shorter dipstick (and tube):
At the end of the day, Junior was back in his building spot, and the Mattituck was cradled back on its pallet. Junior is sporting a bunch of blue tape labels telling us what is going to go where on the firewall ? one of the most important outputs of the session:
So it was back to the computer this evening to place a fittings order and do a little photogrammetry on that prop governor bracket. Looks like it will be fun! I expect it will be a few weeks before junior gets his new engine ? lots of little things to get done before we hang it for good.
Paul
Paul
