647jc
Regarding LED Nav and Strobe installations; I?m considering an AeroLED installation and wondering how others have wired and protected the installation. According to the AeroLED installation document for the Pulsar EXP combination NAV / Strobe unit, they recommend budgeting .5 amps per NAV and 3 amps per strobe. 'Breaker size will depend on the number of lights installed'. They also recommend a 3 conductor 20 gauge shielded cable run to each unit.
I would like to install 3 of these units, and connect them to one NAV breaker @3 amps and one strobe breaker @10 amps. If I use a 10 amp breaker for the strobes I would need to run 12 gauge wires to each of the strobe units if I didn?t want to break any wiring rules. This would mean I need to locate a source for 3 conductor shielded 12 gauge cable which is very hard to find and horribly expensive. To use the recommended 3 conductor shielded 20 gauge cable, I would really need to fuse or provide 3 amp breakers for each of the 3 strobes assuming about a 15 feet run to each unit.
I?m curious how others have installed these systems, a small breaker for each strobe and use 20 gauge shielded cable or one large breaker and use 12 gauge cable or one large breaker and still use the 20 gauge cable which violates wiring rules.
