I just powered up the panel and checked the trim function. I do get a hum at the actuator in one direction but nothing when the switch is reversed. I do recall testing the actuator as per the plans when the actuator was installed and wired and all went well. As of now I have triple checked the wire/pin location in the d-sub connector and all is well. Just wondering if anyone else has had this problem? Thanks in advance for your help.
